It is currently Mon Jun 29, 2026 12:03 am
PostPosted: Sun Feb 06, 2011 1:41 pm
Ok I can't get the engine to slide completely flush with the transmission in my 4x4 LUV. The clutch is perfectly centralized and correctly installed. But when I get it to slide on the transmission shaft it will slide all but the final 1/2 inch. Any info on how to get it to slide the rest of the way on or maybe a problem I may have please let me know. I've installed several engines on manual transmissions before but I have never ran into this problem.
When in doubt floor it. If you can't floor it then you've doubted yourself.
PostPosted: Sun Feb 06, 2011 6:29 pm
Put a jack under the front of the tranny. Jack it up or lower it ever so slightly to make sure they are lined up with each other. The tranny shaft has to fit in a bushing in the rear of the crankshaft.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sun Feb 06, 2011 8:43 pm
There a dowel pin or 2 on the bell housing. They need to be lined up perfect for the transmission to slip over them. Just keep jiggling it around and pushing on it. A PITA.
PostPosted: Sun Feb 06, 2011 9:19 pm
Actually I found out what it is and it makes no sense. The transmission shaft is hitting the inside of the crank on the other side of the pilot bearing. I have no idea why this would happen.
And yes I know the whole jack thing, like I said I've done this before many times (my dad was a mechanic and I am too just not as a job).
PostPosted: Mon Feb 07, 2011 12:06 am
I have had them hang up about 1/2 inch or so and I just moved the clutch release arm (to release the clutch) and it slid in the rest of the way. Just something to try.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 68 guests
