It is currently Tue Jun 23, 2026 6:13 am
PostPosted: Thu Nov 25, 2010 12:45 am
Ok yall try not to laugh at me to hard but I have a 1980 luv 4x4 and I'm simply changing out an alternator on the alt I have 4 entry points which coordinate with letters F,N, bat and E I figured out where everything goes cept for E and that has a screw in the hole with is really loose , so do I take the screw out and put this black wire that is grouped toghter with the other wires that go to my alternator or what?
PostPosted: Thu Nov 25, 2010 7:40 am
I saved this for when needed: On the 6 wire plug from the VR white red = W = fuel pump and charge light, white = W = ignition, white blue = B = battery, black = E = earth, British for ground, white black = F = field, the stem of the Tee connector to the alternator, and white green = N = feeds back to the VR.
To work on Jap stuff, you need to know a little British.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 77 guests
