It is currently Thu Jun 25, 2026 5:54 pm
PostPosted: Wed Oct 13, 2010 11:14 am
Is it normal for the heat from the catalytic converter to get so hot that it is to hot to touch on the passenger floorboard right above the converter?
PostPosted: Wed Oct 13, 2010 11:40 am
NO! Check to make sure your exhaust has not been bent.Also you might check the heat shield on the catalytic converter.
