It is currently Sun Jun 07, 2026 1:22 pm
 Post subject: brake upgrade
PostPosted: Tue Aug 19, 2003 9:54 am
dose anyone know if there is any brake upgrades for my stock axels. I am having a hard time stopping with these 30 in. tall tires on it. so if anyone can tell me how I can stop better.
PostPosted: Tue Aug 19, 2003 3:47 pm
Have you bled the brakes yet?Because before I bled my brakes I had problems stoping with a 22 inch tire. 8O Oh,if the pedal feels soft you may be low on brake fluid or they need to be bled,and you might need new brake pads.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Aug 19, 2003 4:11 pm
i would do a brake service. If that dosent work try downshifting to stop better (in both my trucks i never give any presure on the brakes untill imk about stopped anyway). If that still isnt good then try getting bigger disks from a trooper might work. Ask Karanosuke for the dimensions on a troopers brake disks.
PostPosted: Tue Aug 19, 2003 9:24 pm
what year of trooper can i get the brakes off of. And will they bolt striaght on with no major mods to do and what will i all need to do this. I still have my stock axels on it to.
PostPosted: Wed Aug 20, 2003 4:50 pm
well im not 100% shure if the trooper has bigger discs up front. If it does im perty shure 80-85 troopers had the same axle up front so it should go right on. Another place to ask would be the isuzu forum on pirate4x4.com.
