 Post subject: No headlights
PostPosted: Thu Aug 12, 2010 5:04 am
Hi all, pretty sure I know the answer but I figured I'd ask.
Drove to work this morning and thought my headlights were really dim but they were just not coming on (tons of street lamps on the roads I travel).
All the fuses are good, the high beams won't come on either. I figure the combination switch is shot. Can anyone confirm? Going to see if I can salvage the switch but we'll see. Anyone have a good spare laying around they would part with? lol
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
 Post subject: Re: No headlights
PostPosted: Thu Aug 12, 2010 5:51 am
Before you replace the switch, check the fuse box. Its parts are riveted together and often become corroded and things don't work even with good fuses. I took my fuse box apart a number of years ago and soldered the pieces together. The truck runs better since then than when 5 years old.
PostPosted: Thu Aug 12, 2010 1:50 pm
Labman nailed it. Super corroded ground in the fuse block. Can't wait to get my swap started, swapping to a blade fuse box!
