It is currently Sun Jun 07, 2026 9:05 pm
PostPosted: Wed Aug 11, 2010 7:03 pm
Hey all,
The Phoenix sun has claimed most of my interior. Dash? What dash? Anyway, anyone know of a cheap upholsterer in the Phx area that will do the seat (including new padding) for a reasonable rate? I dont care about the dash, but if they can make a nice cover for that too, then all the better. Does't have to be beautiful, just better than the foam-dust I'm dealing with now. Thanks!!!
PostPosted: Thu Aug 12, 2010 4:29 pm
dude, go to o'reilly's and get a seat cover. runs you about 30 bucks give or take, and it will last quite a while.
PostPosted: Thu Aug 12, 2010 5:37 pm
Seat cover isnt going to last very long or be very comfortable if there is no foam underneath it.
I would start calling upholstry shops in the phone book or asking street rod shops who they would recommend.
PostPosted: Fri Aug 13, 2010 2:12 pm
I have a bench seat. The seat is in good condition. The only thing bad about it is the driver side foam is a little soft. I live in phoenix as well. We should meet up sometime and check each other trucks out.
PostPosted: Fri Aug 13, 2010 5:21 pm
I tried one of these, and it rotted into dust in 6 months. Plus, the foam is toast too.
PostPosted: Fri Aug 13, 2010 5:56 pm
Check Summit Racing and JC Whitney's for bucket seats unless you want to keep the original seat in it. My son took the bucket seats out of an '87 nova and put them in his LUV.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sun Aug 15, 2010 8:00 pm
I just put buckets in mine from a late model Cavalier/Sunfire. ($20 each @ scrapyard)
Also, the bench from a mid 80's-mid 90's Toyota is a pretty straightforeward swap if you prefer that.
Check your local yards. :D
Image1980 4x4, 3" body lift, G180/G180 head, Pacesetter header, Offenhauser Dual Port Intake, Weber 32/36, Electronic Ignition, Glasspack & a Smokestack.
PostPosted: Tue Aug 17, 2010 12:01 pm
Were the buckets from the Cavalier an easy install?
PostPosted: Mon Aug 23, 2010 10:11 pm
the mazda b2000/2200 seats were easy as can be to install all that is needed is a riser bracket made to level seat out on the side towards the trans i got a piece of 1/8 inch flat bar from home depot and cut to size, bent and drilled holes and bolted in with new bolts from depot as well they were 25 bucks off craigslist and the match my interior too. work great then got a risen center console from g.i. joes
