 Post subject: Firing order
PostPosted: Sun Jul 18, 2010 5:06 pm
Does anyone know the correct firing order for the stock 1.8 in a 72 luv???
Thanks
 Post subject: Re: Firing order
PostPosted: Sun Jul 18, 2010 6:03 pm
http://forums.luvtruck.com/search.php
PostPosted: Sun Jul 18, 2010 6:58 pm
There is only 2 firing orders on inline 4 cyl.
1342 luv
1324
PostPosted: Tue Jul 27, 2010 2:06 pm
I second TILTED's reply, use the search tool! Also, get a manual, or two, or three. I have a Chiltons, Haynes, and Chevy manual for mine.
But yes, as tj white said: 1342 CCW is the correct firing order. Never trust the numbers or arrow on new dist. caps, chances are that the arrow, numbers, or both are wrong. If you get everything wired up and you have no power above idle and lots of backfiring, you probably wired CW (1-2-4-3) instead of CCW (1-3-4-2).
