It is currently Fri Jun 26, 2026 12:06 am
PostPosted: Sat Jul 03, 2010 10:43 pm
Well it would appear as if im in need of replacing my head gasket
but i have a 1973 g180
first time owning a pre-74 chevy luv and i was told that this motor has duel timing chains
if so is the head gasket the same??????
and if not where can i find one, im not luvin the new luv its making me miss work
Also anyone owning a 1972 needing any parts?
i raided a 72 in the junk yard today and got some decent parts
lemme know
8)
Image Image
PostPosted: Sun Jul 04, 2010 12:30 am
http://www.oreillyauto.com/site/c/detai ... gasket+set
the procedure is similar, but the BEST source of information is going to be a factory/chassis service manual. Ebay is your best friend in cases like that.
PostPosted: Sun Jul 04, 2010 8:37 am
Figuarus wrote:
http://www.oreillyauto.com/site/c/detail/FEL0/HS8399PT.oap?year=1973&make=Chevrolet&model=Luv%2BPickup&vi=1054279&keyword=head+gasket+set
Or the classifieds section here, I, along with many others, have them available... :lol:
PostPosted: Sun Jul 04, 2010 4:48 pm
Im not concerned about the procedure
I was wondering if the head gasket was the same?
:egeek
Image Image
PostPosted: Sun Jul 04, 2010 5:46 pm
1972, 1973, and 1974-1975 are three different engines. Be sure to get 1973 stuff (i.e. a head gasket, timing set) if that's the engine you have. That said, you can usually use the NAPA or Kragen website to check if part numbers match up for different years using the same gasket.
PostPosted: Sun Jul 04, 2010 7:43 pm
Found It, Ordered It.
Haha
Thanks.
Anyone In Need of parts for a 1972?
8)
Image Image
