It is currently Fri Jun 26, 2026 1:07 am
 Post subject: looking at a 79 4X4
PostPosted: Fri Jun 25, 2010 7:20 am
New guy here and I am looking at a 79 4X4 for sale locally.
Other than 30 years of rot and rust ( which is LESS than I expected ) what should I be looking at. What problem areas are specific to these pick-ups??
The truck is showing 48,000+ but I am assuming at least 148,000.
Thanks
 Post subject: Re: looking at a 79 4X4
PostPosted: Sat Jun 26, 2010 11:51 pm
Frame rails definitely, obviously check the engine for knocks/smoke/milky oil, I'd test out the 4 wheel drive as well, make sure everythings working like it should.
PostPosted: Mon Jun 28, 2010 8:34 pm
Thanks dudeus for the tip on the framerails!!
it amazes me that no more people have responded.........I posted the same question on one of the gun sites I spend too much time at and received 15-20 replies.....
PostPosted: Wed Jun 30, 2010 10:13 pm
it's like buying any other vehicle.
the simple stuff :
check fluids and their condition - they can tell you alot about the truck without even driving it.
check for loose parts/ jimmy-rigged fixes and note them - some repairs are not always done right obviously.
if you need tires, take that into account and price them. standard sizes for these trucks are 195/75-14
drive it - make note of any noises/ quirks that are present or that affect the truck's driveability.
check electrical harness condition - a quick visual inspection of the harness itself can tell you whether splicing or modification has taken place.
lastly, just take a look at overall condition. look for the obvious stuff and keep it in mind when making offers.
if you can, or have access to, take the truck to a mechanic to have him give it a look-over and see if there are any underlying problems.
also, this forum provides a wealth of information, so if you need to repair, say....a head gasket, we can help you fix it with procedures and information.
if you find some problems or have concerns about this truck, just ask us here and we will do the best we can to answer you
PostPosted: Thu Jul 01, 2010 5:08 pm
Thanks
