It is currently Fri Jun 26, 2026 3:31 am
PostPosted: Fri Jun 25, 2010 10:23 am
I'm off a tooth when I have everything set up, or is this the mark it's supposed to line up to?
I'm at zero on the bottom tooth-
I'm at zero with the cover and balancer on-
I'm not at zero on the top tooth on the gear-
PostPosted: Fri Jun 25, 2010 2:07 pm
I found it-
It's some times right under your nose, thank goodness for the search button and the stickies on top of the threads.
viewtopic.php?f=5&t=12104
The book confirms it also-
Quote:
Pg 1B-8 #11 When refitting the timing chain align the mark plate on the chain with the crankshaft timing mark (see illustration). The mark is on the front side of the chain with the greater number of links between mark plates on the chain guide side. The crankshaft sprocket is fitted with the marked side forward and the triangular mark in alignment with the chain mark plate.
I'm use to lining up the zero marks on both sprockets.
Users browsing this forum: No registered users and 56 guests
