It is currently Mon Jun 08, 2026 12:38 am
PostPosted: Tue May 25, 2010 9:00 pm
Hey guys are there any sites or companies that make hood release cables for my 79' ? If not, what year Luv's release cables will fit my 79' if I need to look through the local Pick-N-Pull. Also I am missing my passenger side Headlight bezel, what year for single headlights will work and are there any sources for these out there ? Any help would be greatly appreciated...
1979' LUV Mikado 4x4 1.8L 4spd, 3" Body Lift, 235/75/15s Scrambler wrapped around Centerlines, Pushbar w/ KC Lights, Bed Roll Bar, ect.
PostPosted: Tue May 25, 2010 9:30 pm
I could not find one so i went to a motorcycle dealer and got a front brake cable, the original luv release is a hard cable and the cable i bought is a flexible one.I had to enlarge the hole on the hood release mechanism and run the cable on the opposite side ( PASSENGER ) of the original one,then i found a hole in the firewall to route it through and it works like a charm.
PostPosted: Wed May 26, 2010 11:00 am
cable , all 72/80 should work ... for the headlight bezel 78/80... if you cant find local i have them... but see what you can find there first unless you need it like right now...
PostPosted: Wed May 26, 2010 12:52 pm
Thanks for the help guys. CT- Thanks for the idea, I have a local cycle cable shop who should be able to make something up if I can't find a used or NOS cable. ctmandu- I'm in no hurry at the moment but if I can't find the bezels locally I may have to hit you up. Thanks again
PostPosted: Wed May 26, 2010 2:30 pm
your welcome... yep lots of guys have used the bike shops for the cable and they say they work great...
PostPosted: Wed May 26, 2010 5:28 pm
Your welcome McKenna,The cable i bought was a standard lenght around 5 foot long and if you need some pictures let me know.
PostPosted: Thu May 27, 2010 1:27 am
I'd love to see some pictures of it, if it wouldn't be too much trouble. Cheers
