It is currently Sun Jun 07, 2026 10:29 pm
 Post subject: Heat sensor
PostPosted: Wed Apr 07, 2010 11:52 am
Hi everyone,
I just bought a 1980 4x4, the heat light is on all the time and the temperature gauge is inoperative, I think it may be the cooling sensor, but this truck has being neglected for long time and the engine is covered with mud and can’t find the sensor to replace it, does anyone know where is the sensor located?
 Post subject: Re: Heat sensor
PostPosted: Wed Apr 07, 2010 6:45 pm
Look under the intake manifold just behind the distributor.
PostPosted: Wed Apr 07, 2010 8:41 pm
Right, a mirror helps.
PostPosted: Thu Apr 08, 2010 1:01 pm
Thank you! :D
PostPosted: Fri Apr 23, 2010 11:11 am
felipito wrote:
Hi everyone,
What state are you in? My 80 4x4 is in Calfornia, and there's a sensor that screws into the catalytic convertor (I think this is CA only) and that caused my heat light to come on.
PostPosted: Wed Apr 28, 2010 1:18 am
its right inder the thermos it looks like a bolt hex with a nail head sticken out mine had the same prob theres a wire that conects to it that might be disconected or something its the same as oil pressure sending unit square little clip that slide on the end of it...... good luck
