It is currently Sun Jun 07, 2026 5:16 am
 Post subject: Seats
PostPosted: Tue Aug 12, 2003 3:01 pm
I am attempting to rebuild a 1979 4X4 and had to remove the seat, due to the rats that used to live there. Will seats from an S10 fit? Any help will be greatly appreciated.
PostPosted: Tue Aug 12, 2003 6:48 pm
Just about any seats can be made to fit... I had seats from a Mitsubishi Galant in mine. I had to drill new holes and use wood blocks for spacers so they wouldn't lean forward, but it was a clean installation, and looked mostly stock...
I don't know of any other seats that would just "bolt up" though.
PostPosted: Tue Aug 12, 2003 11:41 pm
I know a guy that put a Toyota pickup bench seat in and only had to drill mount holes.
PostPosted: Tue Aug 12, 2003 11:57 pm
i was looking into the Honda CRX seats, older Mazda RX7. some small seats im pretty tall guy so i need the skinny seats i hit the stearing wheel with my knees with stock bench seat :evil:
PostPosted: Wed Aug 13, 2003 4:57 am
I had RX7 seats in mine. the outside front mount only needed a hole drilled, but the inside front needed a block to mount to.
they fit nicely.
im 6'4"
03Cobra
PostPosted: Fri Aug 15, 2003 2:31 am
well s-10s are roughly the same width so it should work. But since you have to change em i would go for buckets.
