It is currently Sat Jun 27, 2026 6:47 pm
 Post subject: Recurve Dist.
PostPosted: Fri Feb 26, 2010 9:17 am
 Post subject: Re: Recurve Dist.
PostPosted: Sun Feb 28, 2010 12:38 am
That seems like a neat idea, I'm going to go read more about changing distributor advance curves. I assume putting in lighter springs lets advance come in a little sooner, which for WOT operation could be good.
PostPosted: Sun Feb 28, 2010 9:49 am
I have notice LUV motors love advance and respond well to curve kit. I live in 2700ft and can get away with the lightest springs, but when I go into Los Angeles I have notice it will ping just off idle unless I run premium gas. With the light and medium spring I can run low grade gas and not ping at all and get good throttle responce at 2700ft and at sea level. Use a timing light with dial back timing advance and gragh your curve according to rpm vs timing. My curve is in all in by 2800 rpm.
PostPosted: Fri Mar 05, 2010 2:35 am
Here is some more dist 411-
Users browsing this forum: Google [Bot] and 52 guests
