It is currently Sat Jun 27, 2026 1:31 pm
PostPosted: Fri Mar 05, 2010 10:50 am
The sticky from the trooper install doesn't get a lot of traffic from the guys that have already done it so I figured I would post up a new thread and add the info to the sticky afterwards!
What years models can you scavenge parts from to complete this install? Pup, Trooper, Trooper II, 2x4, 4x4, manual, auto, 1982(?)-????
There are practically no P'ups in the south east (at least none in the parts yards) and Troopers are not the most common. I believe I saw a setup once but it was on an 87 or so Trooper II 4x4, but I didn't want to spend the time/money to yank it only to find out it wouldn't work.
All input appreciated as it's going into the sticky!
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Fri Mar 05, 2010 12:14 pm
I can't add a lot, but this might be helpful: Don't get a P/S pump from a diesel (unless it's going INTO a diesel). The bracket is different.
PostPosted: Fri Mar 05, 2010 1:53 pm
good luck... i have been searching for a 87 trooper box for a while now. have yet to find one.
A.j.
PostPosted: Sat Mar 06, 2010 11:51 am
Let's not let this one die, I know it's been done enough that someone can chime in on at least what model they got theirs from!
This is for the betterment of all LUVs. :wink: Let's keep it going.
PostPosted: Sat Mar 06, 2010 12:11 pm
BEETLEVH wrote:
Sure thing, bcg...
First and foremost, ALL parts I needed came off of an 86 Isuzu Trooper (with the round headlights) that had the 2.3L 4 cylinder G200 engine.
Parts that I took from that vehicle:
-Steering Gearbox w/Pitman arm* and U-Joint from steering shaft**
-Lines (high pressure and return lines)
-Reservoir (make sure it has the black rubber seal and filter inside)
-Power Steering Pump w/ "V" belt pulley
-Bracket (1) for reservoir
-Brackets (3) for AIR PUMP on driver side of engine.***
-ALL bolts for everything I took off (proved to be a VERY smart move)
*Make sure you know the size of your Pitman arm. I found that the 86 (and possibly earlier Troopers) had the correct size for my LUV whereas the 87 and up were too short.
**The steering shaft on the Trooper is notched at the end and the notch slides into a U-joint unit. It is this U-joint unit that has the splines at the end which fit onto the steering gearbox. You MUST take this U-joint unit, the flexible coupling on your LUV will NOT mate up to the input shaft on the Trooper box. I had a guy at the yard cut it out with oxy-acetylene.
***The reason that you're taking the brackets that hold the air pump on the Trooper's engine is because the power steering pump is on the passenger side. On the LUVs, this is where our distributor is, so the big bracket that holds the pump can't fit there. This is why we have to use the air pump bracket to hold the power steering pump on our LUVs.
For most of you, once you have these parts in your garage you'll be able to put it together after modifying the brackets a bit. When I say modifying I don't mean welding... I don't own a welder and I got through this whole project without needing one. I mean you may need to drill a hole here and move the alternator bracket there, but thats about all. This should be good enough to get you started and I will post more in depth stuff as you ask it. If you need, you all can even e mail me at BEETLEVH@aol.com. In the subject line put "LUV Power Steering" or something so I don't think its spam. :)
pjhooft wrote:
Just to throw in a little extra here is the Interchange for the gear box....
1984-1986 Isuzu Trooper
* 1984-1984: 4Cyl 2.2L DIESEL, FI, VIN "S" Base
* 1984-1985: 4Cyl 1.9L Gas, Carbureted, VIN "A" Base
* 1986-1986: 4Cyl 2.2L Turbo, Diesel, FI, VIN "U" DLX
* 1986-1986: 4Cyl 2.2L Turbo, Diesel, FI, VIN "U" LS
* 1986-1986: 4Cyl 2.2L Turbo, Diesel, FI, VIN "U" LX
* 1986-1986: 4Cyl 2.3L Gas, Carbureted, VIN "L" DLX
* 1986-1986: 4Cyl 2.3L Gas, Carbureted, VIN "L" LS
* 1986-1986: 4Cyl 2.3L Gas, Carbureted, VIN "L" LX
PostPosted: Sat Mar 06, 2010 8:41 pm
That's good info, feel kinda silly for missing that. I'll post this up in the sticky in this forum so it'll be a little more accessible at a glance.
Users browsing this forum: Bing [Bot], Google [Bot] and 58 guests
