It is currently Sun Jun 28, 2026 8:43 pm
 Post subject: msd ?
PostPosted: Sat Feb 20, 2010 11:31 pm
I have the isuzu electronic dist in my 76,would a msd box help? is it worth the price? I plan to find one used.Thanks guys.
76 mikado project,mean green
 Post subject: Re: msd ?
PostPosted: Sun Feb 21, 2010 12:56 am
Just plugged mine up today! Wow what a difference before i hooked it up i didn't know what was going on with truck after i hooked it up it was running like champ. I just have to get timing and fuel/air mix down... It helps with the higher RPMS the missing that normally happens when these trucks wine out. Hoping my MPG goes up as well I already think its worth it and i haven't even started driving it yet!
PostPosted: Sun Feb 21, 2010 3:02 am
do you have a stock dist. w/ points ?
PostPosted: Mon Feb 22, 2010 5:07 pm
Yup stock points... Someone told me after having the MSD Box the Petronix or the elec dizzy would not do me much better....But i think the box makes huge difference...
PostPosted: Wed Feb 24, 2010 8:01 am
X2
I had ignition issues. Burt points, bad coil, bad ballast risistor. I used a 6AL cause I had it on a Camaro and took it off with the msd coil and put on my luv. Ran sooo much better. I was able to find the other issues I had, stuck vacuum adv, stuck mech adv. bad spark plug wires. Once all these issues were delt with the truck ran great and would cruise @70mph on the freeway (truck could go @90mph on the freeway, but motor was screaming, sounded sweet though, blew a tire and cured me.) and still got up wards of 25mpg
Users browsing this forum: No registered users and 76 guests
