It is currently Mon Jun 08, 2026 3:58 am
PostPosted: Fri Feb 12, 2010 5:17 pm
I just purchased the following from advanced auto:
http://shop.advanceautoparts.com/webapp ... 6083137___
The stock hoses have a retention prong that fit into the caliper but this one does not, which isn't a huge deal, however the fitting only goes in about 1-2 threads and stops.
Anyone gotten these before or can tell me who to go through to get the correct ones since all the sites seem to be the same or similar?
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Fri Feb 12, 2010 5:25 pm
Different thread pitch is my guess. I got mine from my local car quest with no issues...
PostPosted: Fri Feb 12, 2010 7:47 pm
The back brake fittings are M10 x 1.00, don't know why the fronts would be different. If they gave you a SAE fine thread fitting they will be close but they won't fit. When I got new back lines a while ago one parts salesman referred to them as "3/16 metric" and they fit. You might try that terminology.
