It is currently Sun Jun 28, 2026 7:34 pm
PostPosted: Tue Feb 02, 2010 10:55 am
I have a 1978 Chevy Luv Mikado and this year they have decided that my truck needs an evaporative canister. Does anyone know where I can find information as to whether it is required or not?
PostPosted: Tue Feb 02, 2010 10:02 pm
In CA. at least, 78 did not have a charcoal canister. 79, IDK and 80 did. This confuses my smog tester guy every time, when I take in my 78 and 80. You should have a vapor recovery tank in the bed. That's whats behind that cover in the side of the bed right behind the driver. That should be good enough for a 78.
PostPosted: Wed Feb 03, 2010 1:26 pm
rondog X2
PostPosted: Wed Feb 03, 2010 2:24 pm
if you see your state reff. he can tell you what you need. since your 79 did not come with a charcoal canister he may exempt your truck from having that. the smog tech that I talk to told me that. I know my truck will not pass smog so he told me to see the reff and have him smog it and see how it does the older the cars and trucks get, its harder to get parts. so with that they will let some things pass and he will give some sort of certificate thats given to the smog tech. that what I was told anyway and if that make any sense to you. i have a 79 luv and dont need the canister, and I live in california. but i always thought that the vapor recovery tank was the canister, it does the same thing....kind of. :?:
1975 luv daily driver.
Project-soon to be revived
PostPosted: Wed Feb 03, 2010 3:29 pm
What does it do?
2006 GMC Sierra 2500 HD
PostPosted: Wed Feb 03, 2010 4:45 pm
The vapor canister system contains any gas fumes from the tank so they don't escape into the atmosphere. On the Luv you have a sealed, nonvented gas cap so that when the engine is off the fumes are stored inside the engine crankcase (yep thats right). When you start the engine the fumes are drawn back into the engine intake system for burning. That is what that little valve on the firewall is all about. It tells the fumes where to go and when.
Other vehicles use a carbon canister, Luv chooses to do it this way. Both do the job ok.
PostPosted: Wed Feb 03, 2010 5:04 pm
:signnoway :signjk
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Feb 03, 2010 5:46 pm
Egg is correct. The truck will have to pass a pressure test on the evap system. It's no big deal, I have had several pass. It's actualy a easy system to repair if it does leak.
PostPosted: Wed Feb 03, 2010 11:36 pm
Mine leaked on my 80, and he didn't test the 78. He let me go on it though.
So that's odd that the 80 has both the evap tank and the charcoal canister.
PostPosted: Thu Feb 04, 2010 2:28 am
Quick question. I have an '80. Isn't the canister just behind the right headlight? Or is that a vacuum res?
PostPosted: Thu Feb 04, 2010 9:24 am
PITA Old Fart
In the late 70's and on up into the early 90's you'll liable to find a lot of wierd stuff when it comes to emissions on a lot of vehicles.
Nobody in the vehicle manufacturing business really knew what the hell they were doing and just basically were throwing crap on the engine trying to pass emissions standards that were frequently changing. And it's not like they really wanted to or were very enthusiastic about it anyway.
That's why you see old cars with tons of vacuum hoses all over the engine connected to goodness knows what POS doo-hickey that never worked right, or a gazillion wires connected to a ton of crap that no longer works. And all of that PITA crap was crammed into an engine compartment designed so cramped that even a highly skilled and well trained freakin' contortionist couldn't see OR reach it...lol
Yep..one big warm and fuzzy bundle of combination vacuum, electric, pnuematic, hydraulic, electronic, chemical and metalurgical goodness.
All designed for all the guys (and gals) like us.
BTW cheryilea - welcome to the best dang automotive site on the 'net!
PostPosted: Thu Feb 04, 2010 9:51 am
That's the canister.
PostPosted: Thu Feb 04, 2010 11:56 pm
Evap canister is as stated in use for the vapors from the fuel tank.
Charcoal canister is used for the vapors comming off of the carb. Usually a large line to the top of the float bowl, a vacuum line and a line that goes back to the tank or evap canister. Some years had both.
PostPosted: Sat Feb 13, 2010 8:27 am
I agree with rondog that the 1978 LUV California emissions vehicle does not have a vapor cannistor. I purchased my LUV used in Glendale, CA in 1980. It was manufactured in March 1978. Not too sure about the Federal models, but I don't remember ever seeing any cannistors on that year of LUV at the wrecking yards here in Colorado. The mixture control valve for my 1978 is a very rare item too to find. Found one in Denver years ago, and it was bad. That must be a California emission item too.
Arapahoe county (Metro Denver), Colorado has no smog checks on collector licensed plate vehicles which are 25 years or older. Otherwise, it was an annual check. They have on-ramp emission testers via trucks here. I zoom past and the display screen in big bold red letters certifies that my truck has FAILED. Good luck.
PostPosted: Fri Feb 04, 2011 10:54 pm
I just got a 79 4x4 (California) that I'm trying to smog. All the numbers were excellent but it FAILED the "Fuel EVAP Test" and the dude marked MISSING under Fuel Evaporative Controls. He also wrote "Looks like vehicle is missing the charcoal canister (EVAP canister)" on their service invoice. He kept pointing to the cylinder looking thing on the emissions diagram sticker on the bottom side of the hood, saying that part was missing. I tried to find one online and it seems like no one sells it or it might not exist? Local parts stores all said try a dealership or a junkyard, they don't have it. Anyone know where I can find one or if my Mikado even came with one? Maybe it's that thing behind the bed you guys were talking about that's bad? Could that be the part labeled on that diagram? From what you guys all said here I'm not exactly sure if my particular (California) model came with one.
PostPosted: Sat Feb 05, 2011 8:15 am
I'm glad I live in NC. No emissions testing for vehicles 1995 and older!
1990 Chevy Suburban
PostPosted: Sat Feb 05, 2011 1:09 pm
Just noticed the other sticker under the hood says "This vehicle conforms to the Federal and California EPA regulations for a new 1980 model" way at the bottom. According the DMV registration the vehicle is a 1979. I'm thinking maybe the hood was swapped somewhere down the road before it was last painted? Where they that strict about the smog crap back when they sold it that they would have that as some law that it has to conform to next year's standards? Anyway, some of the earlier posts here said the EVAP leak problem was easy to fix, care to elaborate?
PostPosted: Sat Feb 05, 2011 5:30 pm
I have a smoker that I put onto the system amd pinch off a few hoses andthe smoke comes out of the hole.
Users browsing this forum: No registered users and 80 guests
