It is currently Mon Jun 08, 2026 12:38 am
PostPosted: Tue Jan 19, 2010 7:22 pm
Greetings, I'm finishing my Luv project and need info on the two front bolts that go thru the head into the timing chain cover. This particular Luv did not have any installed (no leaks or anything), but I assume that they should be there. I'm guessing that they are 8mm or 10mm 1.25, but I'm hoping someone has a bolt length also.
Thanks!
PostPosted: Tue Jan 19, 2010 11:06 pm
i dont remember the thread pitch, but i remember they were no longer than about 2 inches.
PostPosted: Wed Jan 20, 2010 10:21 am
just had mine off! 2 weeks earlier i could have checked! If i remember correctly they looked a lot like the oil pan bolts
