It is currently Mon Jun 08, 2026 1:44 am
 Post subject: Gas gauge issue
PostPosted: Wed Jan 20, 2010 10:58 pm
Undefeated in Trivia
When I'm out of gas completely, my gauge shows 3/4 of a tank. After putting in about 7 gallons, it showed a 1/4 tank. And as I drove it, and used the gas up... the gas gauge slowly climbed back up toward 3/4 tank. Any clues what may be wrong? I'm not sure what would cause the gas gauge to run backwards.
1980 Shortbed Mikado 4x4
1977 Chevy K20, a little more than mild 350, sm465, np205, 2.5" suspension lift, 37" tires
1995 Ford F150, 300 I-6, ZF-5, bw1356, 6" suspension lift, 3" body lift, 36" tires
 Post subject: Re: Gas gauge issue
PostPosted: Thu Jan 21, 2010 12:01 am
maybe the two wires are hooked backwards just a thought
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Jan 21, 2010 10:02 am
You have the wrong sender in the tank, I bet you have a standard GM sender, it works backwards from the stock LUV one. (Please dont ask me how I know)
Users browsing this forum: Baidu [Spider], Google [Bot] and 63 guests
