It is currently Mon Jun 08, 2026 1:37 am
 Post subject: What to do???
PostPosted: Fri Dec 18, 2009 8:05 pm
Im new on here and this is my first truck and its all stock.
it's a 1980 Luv 4x4 mikado
i have no idea what to do to itand i have a 3" lift kit thing in a box and want to get it lifted eventually but dont know how to at all.
also my 4hi is slipping out. any suggestions on what that is?
i wana get a roll bar(thing that goes in the bed by the cab?)
and also a front bumper. any suggestions where to get those?
ANyone got any suggestions on what to do to it?
1980 chevy luv 4x4
 Post subject: Re: What to do???
PostPosted: Fri Dec 18, 2009 8:44 pm
Welcome, my first 2 suggestions are to use the search button as all your questions have been asked a few times before and fill out your profile so we know where you are located so closer members might be able to help out.
PostPosted: Fri Dec 18, 2009 9:09 pm
Ditto... and welcome to the site. You are probably better off to tackle one issue at a time and keep your eyes open for other parts, ideas and plans as you go. Figure out what is the highest priority and go from there. You have come to the right place.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Fri Dec 18, 2009 11:35 pm
alright thanx guys
1980 chevy luv 4x4
PostPosted: Sat Dec 19, 2009 12:52 am
4HI slippage seems to be the priority to me...
Welcome to the site!
-Ret
PostPosted: Sat Dec 19, 2009 3:02 am
does anyone know how to fix 4hi slippage? it will stay in for a while but then just pop out after a minute or so
1980 chevy luv 4x4
PostPosted: Sat Dec 19, 2009 9:19 am
There is a spring that is just under the shift boot, that holds the shifter in four hi. Sounds like that spring is gone or worn out. It hooks from the shifter to a bracket I think. You can probably see or feel it from under the truck, so you don't have to disturb you shift boot. They are old and tear easily.
PostPosted: Sat Dec 19, 2009 12:19 pm
thanx for the description ill check it out
1980 chevy luv 4x4
Users browsing this forum: Baidu [Spider] and 44 guests
