It is currently Mon May 25, 2026 10:06 pm
 Post subject: Leaf Springs - 1982 Luv
PostPosted: Fri Jul 18, 2003 2:20 am
My leaf springs on my 1982 Luv are way worn out and need to be replaced. Would new leaf springs for an older S-10 fit it? I can't seem to find anywhere that sells new leaf springs for a Chevy Luv or Isuzu P'up.
PostPosted: Fri Jul 18, 2003 7:55 pm
if you have a spring shop in your area take the springs in and they can rebend em so they will ride like new...
PostPosted: Sun Jul 20, 2003 10:41 am
Resident Sparktrician
The springs on the Luv seem to be the same as any Isuzu truck, so look for Trooper, Rodeo, Amigo, Hombre, etc... springs.
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
 Post subject: Re-Arching the Springs
PostPosted: Mon Jul 21, 2003 11:05 am
On a truck a friend and I did about 10 years ago, we brought them to the sheet metal shop where I worked and used a powered slip roll former to re-arch them. Since we did not have any real way to measure them, we tore them completely down and traced the largest spring on a piece of cardboard. Then we passed it through teh slip roll former a few times until it came to an arch we thought would be close to what was wanted by comparing it to the cardboard template. Then each spring was rolled to fit the one before it. Assembled the springs and stuck them back on. We overarched them a bit too much as it caused the rear to sit a little high. But back them, a slight rake to the truck looked good. So if you can find a sheet metasl shop with a slip roll former, talk to them about this. Oh yea, you might want to clean up any rust from the springs as it will leave a stain on the rollers from the clamping .
Rick
Users browsing this forum: No registered users and 74 guests
