It is currently Mon Jun 08, 2026 2:29 am
 Post subject: Some pic;s of spacers
PostPosted: Sat Oct 03, 2009 7:50 am
the bumper in the back ground i am building for my 4X4.
PostPosted: Sat Oct 03, 2009 8:39 am
IS this the spacer you said you had to take out of your 4x4?
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Oct 03, 2009 2:15 pm
nice fab work there on that bumper! :D sorry havent kept up but is the spacer going under the control arm. is it binding.
1975 luv daily driver.
Project-soon to be revived
PostPosted: Sat Oct 03, 2009 2:26 pm
The spacer go's between the bottom of the control arm and the ball joint thus raising the control arm 1/4" higher then just bolting the ball joint under the control arm.This is also why i had lots of room under the arm to the now removed snubber.
I got the spacer kit through Independent4X4.com
PostPosted: Sat Oct 03, 2009 5:14 pm
ok I get it now. looked those up and understand now.
