It is currently Mon Jun 08, 2026 12:17 am
PostPosted: Fri Oct 02, 2009 7:31 pm
My manual is in pieces. I need to know hwo much water/antifreeze to mix.
PostPosted: Fri Oct 02, 2009 9:43 pm
Coolant capacity is 6.4 qts. I mix mine at 50% so about 3 qts. would be about right.
PostPosted: Fri Oct 02, 2009 10:39 pm
Thank you! I will just mix the whole jug with a gallon of water, that should fill the radiator and leave a little for the reservoir box.
