It is currently Mon Jun 08, 2026 2:51 am
 Post subject: Fuel Filter question?
PostPosted: Tue Sep 01, 2009 8:54 pm
I was just wondering on my 72 how much fuel should be in the fuel filter while running? I believe I have a pressure issue
"You know you gotta LUV me"
PostPosted: Tue Sep 01, 2009 10:37 pm
On mine it's about 1/2 full or so. If that doesn't help you solve your problem describe it in more detail and we can likely help you.
PostPosted: Wed Sep 02, 2009 9:35 am
Well sometimes it runs great but usually only on the freeway when it is just around town it acts sluggish and it sounds like a vw bug I thought maybe fuel pump but I dunno
PostPosted: Wed Sep 02, 2009 11:09 am
You might check the adjustment of the carburetor float level. I can't remember if you have a stock carb or not. On the stock carb there is a line etched in the glass showing where the fuel level should be, if it's too low I would expect to see your problem. On the freeway the engine is not under as much load and is at constant speed, whereas around town you have to accelerate all the time and produce torque.
A problem I have is on tip-in from a stop, the engine bog and then gets going. I've identified that to be the accelerator pump. Also, my fuel filter gets clogged with rust real easily and when it's clogged it runs poorly, similar to the way you describe.
