It is currently Sun Jun 07, 2026 10:43 pm
 Post subject: Suspension Guard
PostPosted: Tue Aug 04, 2009 9:33 pm
So my 79' 4x4 parts truck for my 76' has that cool looking guard in the front under the bumper. I tried getting it off today and putting it on the 76', but it was hell trying to get it off, and it still isnt off yet. Anyone got any ideas??
"If it wont fit, force it, if it breaks, then it needed to be replaced anyway..."
 Post subject: Re: Suspension Guard
PostPosted: Thu Aug 06, 2009 12:03 pm
If they won't come off with an impact wrench or you don't have one, soak the nuts in PB Blaster and wait about 15 minutes. If they won't loosen up with PB Blaster, I bring out the torch and heat the nuts up for about 60 seconds and that frees them up. This method has worked for me many times in the past when nuts and bolts are rust welded together. Just remember to use new nuts when installing on the other truck as the heat will distort the old
nuts.
1980 Luv Mikado-Needs a carb
1990 Chevy Suburban- My new daily driver!
1962 Chevy C-10 StepSide- Work in progress.
PostPosted: Thu Aug 06, 2009 9:32 pm
how many bolts did you pull out??
PostPosted: Sat Aug 08, 2009 2:21 am
I only got the front 2 bolts out, i couldnt find any others. And i got tired of using a hammer to try and get it free.
PostPosted: Sat Aug 08, 2009 9:37 am
look again there should be 2 or 4 more. they are smaller than the others.
PostPosted: Sat Aug 08, 2009 11:54 am
Post a pic of the area you are working in.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sat Aug 08, 2009 12:58 pm
look down at the bottom of the guard there are two bolts up inside
on both sides. good luck
geo
PostPosted: Mon Aug 10, 2009 12:59 pm
Well with the help of my friend i figured out that there were 4 more bolts. After those came out, it just fell right off. thanks for all the help
