It is currently Mon May 25, 2026 11:35 am
PostPosted: Mon Jul 14, 2003 8:08 pm
My chevy luv is flooding to much, I got a new carb for it but it still does it. I start it up and let it run, it runs good at first but starts to sputter and putt after that it wont start. Please help I need my work truck back. :(
PostPosted: Tue Jul 15, 2003 4:26 am
i'd take out the needle and float and see if they need cleaned. it sounds like your float is sticking
PostPosted: Tue Jul 15, 2003 6:12 am
Flip your carb plate over. Wrong air to fuel mix.
 Post subject: thanks for your help,
PostPosted: Tue Jul 15, 2003 5:55 pm
I fixed it all it was was the float level, I adjusted it it works now. Thanks for your help
PostPosted: Tue Jul 15, 2003 6:15 pm
i had the same problem one time. good to hear you got her fixed :D
 Post subject: Thanks for the help
PostPosted: Tue Jul 15, 2003 7:35 pm
thanks for your help, when I had the old carb on there it would do the same thing and I adjusted the float but it still didnt work so I didnt think it was the float on the new carb but thats what it was. Thanks again man. Take care
PostPosted: Tue Jul 15, 2003 8:01 pm
from what i've heard the luvs are pretty bad for that. whenever you have a fuel problem always check the needle to see if it's cloged :D
PostPosted: Thu Jul 17, 2003 7:09 pm
Glad to here ya got it figured out! I was wondering.....before i rebuilt the carb on my 80 luv project.....i would turn the ignition on and watch the carb blow out fuel...was that the float level or the jets??? When i took it apart there was alot of grunge! I cleaned it all with chemtool b-12.That stuff is good stuff! I also adjusted the float and shaved the jets a little. When i start my truck now it fires right up , and if i gas on it the secondary opens fast! It seems like a good thing. Its alot faster on aceleration than my street luv.Anybody know about running leaded fuel in a stock luv engine? I run raceing fuel in my dirt bikes ...but im sure thats quite different! As far as the carb plate or spacer , one side is beveled or fluted on the small side. I started mine both ways ...and it seemed to work better with the fluted side down...anybody really know what side goes up??
Users browsing this forum: No registered users and 59 guests
