It is currently Tue May 26, 2026 1:00 pm
PostPosted: Mon Jul 07, 2003 12:39 pm
:o Does anyone know what could cause the cylendars on a perfectly running engine to not have compression suddenly? It stopped running and no compression in any of the cylendars. I think it might be timing, but can't get enough time to look at it right now.
 Post subject: no compression
PostPosted: Mon Jul 07, 2003 2:29 pm
PITA Old Fart
Take off your valve cover and check to see if cam moves when engine turns over, sounds like snapped timing chain or broken cam gear. Later :twisted: -TAZ
PostPosted: Mon Jul 07, 2003 3:03 pm
if it jumped time bad enough or you broke the timing chain. you have bent valves :( ...the 1.8 izuzu is a zero tolerance engine
PostPosted: Tue Jul 08, 2003 1:32 pm
larps right, the chain may be broken and if it is the valves will have to be replaced and you may have to redo the head as well.
PostPosted: Wed Jul 09, 2003 6:43 am
O...man the dreded busted timeing chain!!
Users browsing this forum: No registered users and 57 guests
