It is currently Mon Jun 08, 2026 4:14 am
 Post subject: timing
PostPosted: Thu Jun 18, 2009 8:27 pm
dose any one know which marks to use to line up the cam gear the cam. then where should the timing marks be for the cam and crank? its a 75 111 cid isuzu 4 cyl its the motor that came in the truck and i can not find any info on the motor any info would help
 Post subject: Re: timing
PostPosted: Sat Jun 20, 2009 7:57 pm
There are several threads out here discussing timing. Checkout Fullaluv's, "Birth of an Engine". That's one that covers it and there are several others.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sun Jun 21, 2009 7:05 am
that motor is not the same its a newer one my is the old style the motor just before that one
