It is currently Fri Jun 26, 2026 10:11 am
 Post subject: which master cylinder???
PostPosted: Wed Jun 10, 2009 6:30 pm
i remember reading on here somewhere thats i could use a master cylinder from a jackeroo/rodeo/pup? cant remember where i read it though..will any of these fit and will they work with drum brakes?
PostPosted: Wed Jun 10, 2009 11:40 pm
Unfortunately disc brake masters don't work with drum brakes. The bore & piston in master move a different volume of fluid, not enough on the disc brake master to push out the drum brake wheel cylinders.
In some setups it can be forced to work but that is no measure of relative safety! It may fail you at any time, likely the worst possible time. It can give the illusion of working under 'normal' driving but then fail suddenly & catastrophically under panic stops conditions!
