It is currently Wed Jun 24, 2026 9:36 pm
 Post subject: Timing
PostPosted: Thu May 14, 2009 8:02 pm
I don't have a repair maual yet so what is the timing for a 1980 LUV?
Rick
Loranger, La
1980 Stepside LUV (Again)
 Post subject: Re: Timing
PostPosted: Thu May 14, 2009 10:24 pm
my books are at the shop but for stock i think it was 6deg. could be wrong but thats what i remember
PostPosted: Thu May 14, 2009 11:59 pm
6 degrees BTDC is correct.
PostPosted: Fri May 15, 2009 9:57 am
Thanks. The 13 degrees it is set on now is probably why it's so lethargic and backfires when I shut it off...
Rick
Loranger, La
PostPosted: Fri May 15, 2009 4:10 pm
The timinmg was set at 13 degrees 'retarded'. Now with it at the correct 6 degrees btc and the idle set to 700-750, I can feel her run better and no more run-on and backfires when shutting her off. Thanks everyone....
Rick
Loranger, La
