It is currently Wed Jun 24, 2026 9:35 pm
PostPosted: Wed May 13, 2009 2:53 pm
Hey guys just to let you know I had a electronic distributor from an 85 imark 1.5 liter, that's right, and I stuck it into the chevy luv to see if it would work and it works just fine. The only problem is you have to use the casing from the elec. dizzy that we use to swap it in (trooper). I already tried it with the points distributor by swapping the shaft and the top part of the imark dizzy but you don't have a place to screw in the module and the wires are too far off. So the everything on the inside works fine but you need the casing. But for any reason you guys need the internal guts the 1.5 liter works just fine.
Users browsing this forum: Google [Bot] and 52 guests
