It is currently Mon Jun 08, 2026 4:47 am
PostPosted: Thu Mar 26, 2009 8:56 pm
I got the drain plug off before seeing if I could get the filler plug off... stupid me. So, I'm gonna fill it from the top but I need to know how much to add.
PostPosted: Fri Mar 27, 2009 12:03 am
my manual for 76 says 1.35 qt.,but you add til it comes out the filler hole on the side of tranny.
76 mikado project,mean green
PostPosted: Fri Mar 27, 2009 8:10 am
I can't get the filler plug off. Did you read my post? Nobody answered in time and I needed to drive so I just put two quarts in, I might drain some...
Thanks.
PostPosted: Fri Mar 27, 2009 9:53 am
I did what you did to my rear axle. :roll: Had to use an air chisel to get the filler plug off, I wasn't about to pull an axle to put fluid in it. Used the air chisel to cut into the side of the plug and make it thread out, not chisel the head off, that wouldn't work. OSH hardware happened to have a metric plug that will fit, although I just used the old one which still had threads on it and some RTV silicone.
Users browsing this forum: No registered users and 69 guests
