It is currently Mon Jun 08, 2026 11:39 am
 Post subject: Double Roller Chain g200
PostPosted: Tue Dec 23, 2008 11:08 am
Hey guys. I have a 1979 chevy luv (Long bed) that i bought to work on as a hobby. I was thinking about starting to work on it. I have two G200 motors that I've picked up that run, one of them is fuel injected the other one is carbureted. I also have the stock g180. Its an original manual 4 spd, but Ive picked up a five speed. Its all been sitting for a couple of years. My question is, who sells a "double roller" timing set for the g180/g200? Is there such a thing?,,,,If there is does the chain fit under the stock cover? Thnx for any help, Vic.
PostPosted: Tue Dec 23, 2008 6:33 pm
it will fit with alittle fillingon inside of cover
part number CS6410 holden 1800&2L d/row timing chian
http://www.romac.com.au/pdf/2005%20C&B% ... 20List.pdf
USA delears....
Nickels Performance Warehouse Ph 423 391 0032 Fax 423 391 0208 TN.
Crane Cams FL Ph 904 252 1151 Fax 904 248 0138 CA.
Engine Rebuilders Warehouse FL Ph 954 792 9702 Fax 954 792 1757 FL.
Per-Fit Corporation MI Ph 616 247 6572 Fax 616 247 4965
Additional Independent Stockists
These distributors purchase directly from our Australian Wholesalers
CV Products Ph 336 472 2242 Fax 336 472 2204 NC.
Scogg & Dickey Ph 800 456 0211 Fax 806 798 4086 TX
PostPosted: Tue Dec 23, 2008 7:18 pm
and here is some more info... look at the 3 pages from the gem site
http://www.ozgemini.com/forums/tech/sea ... 06&start=0
PostPosted: Tue Dec 23, 2008 7:46 pm
Thnx for the information. Does it matter if I order the chain for the G180 or G200?,,,,Are they the same? thnx again.
PostPosted: Tue Dec 23, 2008 9:13 pm
i was told G160 G180 G200 all the same on that... but best to always ask them
PostPosted: Tue Dec 23, 2008 9:34 pm
thnk u.
PostPosted: Mon Dec 29, 2008 2:48 pm
Wow,,,,so far no luck with any of the companies for a double roller chain set. Im waiting on phone calls back from two companies, Engine Rebuilders Warehouse and CV products, other than that no luck.
PostPosted: Wed Jan 14, 2009 10:25 am
Finally, I was able to find someone here in the states that usually has the 1976-1980 g180 engine double row timing set. I tried all of the companies here that Australia said are their distributors. Nobody had them, and were not really interested in stocking them. I found this guy on ebay, his companies ebay name is europarts4auction, he has an ebay store, "Vintage Imports Inc". If you guys already had this information I apologize. This guy (Matt) says he gets them from a company in Australia called "Repco". He sells them for $65.00 plus about $10.00 shipping to the West Coast. I think its a good price. I bought one from him over the phone. The guy had just sold the last chain the day before i called him. He called one of the companies that he sells to and picked it up for me. The guy says he usually has them in stock because he sells them to companies that use this part on some type of industrial machine application. He doesnt put them on ebay because he sells these with no problem without ebay. Anyways, I thought I would share this with everyone, in case you were looking for one. Matt at Vintage Imports (937) 550 4509.
PostPosted: Wed Jan 14, 2009 4:20 pm
Nice! Great find ! I've been wondering if they still made them.
PostPosted: Tue Jan 20, 2009 10:18 am
Sorry guys, im still hunting for a company that will furnish these double roller sets. The guy Matt I talked about above can get the 1-4 series engine double roller set, but is looking into the set for the newer engines. Ill let you know.
Users browsing this forum: Google [Bot] and 52 guests
