It is currently Mon Jun 08, 2026 5:29 am
 Post subject: Draining Battery
PostPosted: Fri Jan 09, 2009 6:58 am
I bought a 80' 4wd stock luv and the battery is going dead. When you have the key "OFF" the GEN light is on. I have to disconnect the battery each time I turn it off so it won't drain the battery. When I reconnect the battery you can hear 2-3 relays CLICK. What or where would be a good starting point to start diagnosing this problem.
Where or who has the best deal on a rebuild kit for the 1.8> Thanks Lee
78' 2wd daily driver (white)
80' 4wd flatbed (red)
80' 4wd driver (black)
80' & 76' 2wd parts trucks
 Post subject: Re: Draining Battery
PostPosted: Fri Jan 09, 2009 12:37 pm
Charging system problem. Start with the alternator, that with defective diodes can back feed current through the regulator and energize relays. A defective regulator might also cause this. What happens if you disconnect the plug to the regulator?
