It is currently Mon Jun 08, 2026 5:29 am
 Post subject: BRAKE ROTORS
PostPosted: Wed Dec 31, 2008 6:09 pm
ANY OF YOU GUYS BUY FROM THIS GUY?
http://cgi.ebay.com/ebaymotors/CHEVY-LU ... ccessories
 Post subject: Re: BRAKE ROTORS
PostPosted: Thu Jan 01, 2009 2:26 pm
Instead of replacing your stock heavy rotors replace them with the lighter vented Trooper rotors.
PostPosted: Thu Jan 01, 2009 5:38 pm
what year trooper is a direct swap?
PostPosted: Thu Jan 01, 2009 6:30 pm
Well i know the ones on my 86 trooper chassis are a direct swap.
PostPosted: Thu Jan 01, 2009 10:01 pm
ok did some searching on here and the 84-86 isuzu trooper rotors will fit fine, even with keeping the luv pads and calipers. I found brand new trooper rotors on partsamerica for 14.99 each
http://www.partsamerica.com/ProductDeta ... 21&PTSet=A
Rock Auto has them for 11.71 each
PostPosted: Fri Jan 02, 2009 8:54 am
i have this place out of california where i get all my rotors called trinet motorsports, found them on ebay, they sell the drilled slotted rotors for the same price or in some cases cheaper than the stock ones, and as you probably know the drilled slotted rotors run way clloer and way less chance of warping. i cant find them now. but i have their phone number if your interested. i have gotten several sets of rotors from them and i have absolutely no complaints
edit--- found their website
http://www.trinetmotorsports.com/
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sat Jan 10, 2009 8:54 pm
good buy here that should fit LUV
http://cgi.ebay.com/ebaymotors/1986-Isu ... ccessories
