It is currently Fri Feb 20, 2026 12:22 am
PostPosted: Mon Jan 05, 2009 7:53 pm
My clutch pedal is a bit hokey feeling, When I press it down it kinda slides/wobbles to the side a little. I looked up under the dash and it has a real small c clamp holding something together :roll: Can't really see it that well. Does any one have a pic of a Pedal assembly out of the truck like laying in your drive way or on a work bench I could look at to try and figure out whats wrong or missing with mine. Thanks
PostPosted: Mon Jan 05, 2009 8:18 pm
Use the search button and you will find numerous topics on this, your bracket is breaking like 95% of the peoples trucks on here have, it will need to be welded or braced back up. Mine did it 3 times.
