It is currently Mon Jun 08, 2026 9:23 am
PostPosted: Wed Nov 05, 2008 2:48 pm
Can anyone tell me where I can buy new head bolts for my 1.9 L engine? Thanks...
PostPosted: Wed Nov 05, 2008 6:30 pm
I have looked with no luck. I'm a oilfield mechanic with alot of contacts, that can get pretty much anything, but they all say they don't make'em any more. Also they said that they are not torque-to-yield, like I thought. I have a machinist that can make them but told me the ones I had were OK, and that if I asked how much it was to make them, I couldn't afford them.(lol) FYI the bolts are metric in every way. I even asked if I could use a grade 8 metric with a washer but they all advised me NOT too. I was told to go find used ones and clean them up good if I needed them. Good luck on your search.
78' 2wd daily driver (white)
80' 4wd flatbed (red)
80' 4wd driver (black)
80' & 76' 2wd parts trucks
PostPosted: Wed Nov 05, 2008 10:31 pm
We've covered this one before. You can do a search for "head bolts 4zd1" to read the long version of the story but here is the short story: http://www.headbolts.com has headbolts for the Isuzu 2.3L 4ZD1 motor and those happen to be identical to those used on the LUV. You can also look around elsewhere for 4ZD1 headbolts like ebay and perhaps find a better deal.
PostPosted: Thu Nov 06, 2008 8:39 pm
Thanks for all of your help. I have completely gone through this motor and do not want to take any short cuts. Thanks for all your help...
