It is currently Mon Jun 08, 2026 5:29 am
PostPosted: Mon Oct 27, 2008 6:55 pm
Somone posted that they had installed a MSD 6A box at one point. I wanted to see if you had any advice about install. Or pictures. I had bought a dizzy coil and ignitor from somone on ebay but the ignitor is bad I cnat get any spark out of it so I was tired of looking and jsut ordered the box hope summit ships fast I want to drive my damn LUV.
Wondering if I can omit alot of the BS factory wires or not.
Thanks[*]I Installed everything last night. I have it in a stock 78 LUV. So far I have it mounted with the blaster 2. I am curently getting a spark from the coil but am getting nothing from the dizzy to the plug wires. Some of the questions that I have are:
1. Do I still have to use the stock wires that went to the old coil or does this replace all of that. I only used the Keyed 12 volt wire.
2. I have an 82 electric dizzy on it there are red and white I am not sure which one is pos or neg! Haines doesnt say.
3. I picked up plugs for an 82 LUV thats what was refered to me.
4 I assumed that the 82 dizzy was not a magneteic pick up so not using the MSD wires for it.
The connections that I did were as followed.
1. Hooked up the Batery POS and NEG cable wires from MSD Box
2. Hooked up the Orange and Black cables to the coil. Black NEG/ Orange Pos
3. Used the red wire from MSD box connected to the 12 volt ignition and then splice to red wire on dizzy
4 White wire to white wire on dizzzy
Im picking up new dizzy to coil wire on my way home dont like the connection it is getting...
I know its a ramble but if any one has ideas I would apreciate it.
