It is currently Mon Jun 08, 2026 6:48 am
PostPosted: Fri Oct 24, 2008 12:26 pm
My father bought an 81 4X4 with a tore up engine. The guy who had the machine before just destroyed the timing sprocket and said that the oil pump was bad.
We re-did the engine from the ground up and it runs fabulous - 900 rpms and all. But as soon as you push the clutch in - the engine tries to die.
I have been through every book and went through every rock of knowledge that I know and I still to this day can't figure out where to look for the problem. I figured it is a vacuum line someplace - but it is alluding me.
Any help?
PostPosted: Fri Oct 24, 2008 12:47 pm
Check your wiring to the carb and the pedals. There are switches on the clutch pedal, gas pedal, and trans for the coasting richer valve and the carb may also have a fuel cut off valve. If some of that was mixed up, the clutch pedal switch could be hitting the fuel cut valve.
The way coasting richer is supposed to work is clutch out, foot off the gas pedal, trans in 3rd or 4th and the valve on the carb opens.
It could also be a wiring fault on the clutch switch of some other kind too. If things were really screwy on the wiring it could be dropping voltage to the coil, killing the fuel pump, or just shorting something out. If the wiring gets bad in the harness it can do all sorts of things. My 79 shorted the reverse light power source to the main alternator hot wire and the end result was the truck would stay running with the key off. Strange wires crossed can make for strange behavior.
PostPosted: Sat Oct 25, 2008 1:05 am
Sounds like the wires to the carb coasting richer solenoid and the fuel cut solenoid are swapped.
PostPosted: Mon Oct 27, 2008 4:14 pm
Thanks 800XL and egg. I will take a trip to the truck and take a peek and see if they are as you say.
It is one of dem dere - stump the chump deals.
Users browsing this forum: Majestic-12 [Bot] and 64 guests
