PostPosted: Wed Oct 15, 2008 9:07 pm
How exactly do you adjust the torsion bars. I couldn't find it in my haynes repair manual (gotta get a chilton). They're resting on the bump stops right now and I want a little bit of space in between them.
PostPosted: Wed Oct 15, 2008 10:39 pm
Pretty easy. There is a large bolt head pointing straight down about under the driver's seat area, one on each side. Turn in clockwise to raise and to the left to lower, turn each one the same amount. A quick look underneath will spot it.
PostPosted: Thu Oct 16, 2008 1:24 am
I found it easier to:
1st spay some WD-40 on threads
2nd Raise the front end up to take some of the weight off (it helps when tighten)
PostPosted: Thu Oct 16, 2008 2:02 am
I came across these links as well i always read alot more than i want
then try to use best judgemnt w/ a little common sense
then it ually ends up at the MECHANICS ANYWAY ... :lol: JUST KIDDING
http://www.planetisuzoo.com/articles.ht ... Adjustment
Also
viewtopic.php?f=7&t=15681&hilit=torsion+bar+index
PostPosted: Thu Oct 16, 2008 11:13 am
Thanks guys I really appreciate all the help!
PostPosted: Fri Oct 17, 2008 12:31 am
Well I adjusted them and someone was right about them "settling". The one on the left is cranked almost all the way while the one on the right is only part of the way but the truck is now level. Thanks guys.
