It is currently Mon Jun 08, 2026 7:58 pm
 Post subject: reliable chevy luv?
PostPosted: Mon Oct 13, 2008 12:07 pm
i love my truck and everything about it. people say that it will never be a reliable vehicle. i do all the matience on it myself. and so far its more reliable then my brothers 75 gmc with a sbc in it. hase anyone kept haveing problems with a motor. or have they been reliable?
 Post subject: Re: reliable chevy luv?
PostPosted: Mon Oct 13, 2008 5:01 pm
It all depends on the up keep and also if you have rebuilt the engine carb and tranny etc even so your truck will and can be as reliable as you want as long as you take care of it just like any other vehicle sure some problems will arise here and there but you can make it a very reliable daily driver just treat it right. Mine has got tranny and carb and engine rebuilt over time but when i drive it, it just purs adn feels solid.
A good friend will bail you out of jail, and even better friend would be sitting in the cell with you saying how awesome that was!!!
PostPosted: Mon Oct 13, 2008 6:55 pm
My 76 still runs like the day my family bought it in 1983. Right now it is parked, but if I needed it, I could boost the battery off and go anywhere.
PostPosted: Fri Oct 17, 2008 2:38 pm
My LUV has been dead reliable-after the 3rd motor.
The first motor had more slugde in it than a laxative labratory septic tank.
The oil guage read "0" PSI, I thought it was the gauge. The engine ran great until ti blew a headgasket which is when I tor eit down to find out the oil pressure truly was ZERO.
The second motor had a cut breather hose that I did not catch and leaked all its oil out. It broke a timing chain. I scrapped the motor.
This 3rd motor had the oil pan gasket tear laterally and leaked out all its oil. I limped it home putting in a quart every few hundred feet, and it is my daily driver, now. I put in Lucas and Mobile 1 15,000 mile and it does very well.
I also rebuilt this motor the best I could afford. I should have put 2 oversize pistons in it, but i just had it honed and new rings put in. It has been extremely reliable.
My truck got 100 times more reliable when I got rid of the Hitahci carb.
It got 100 times mor ereliable than that when I put on aftermakret high energy ignition in it, too.
PostPosted: Fri Oct 17, 2008 9:20 pm
i have two engines both run fine i put new bearings in one but it pumps water out like crazy lol the other is kinda iffy it seems to be covered in oil lol but runs steady at 55 psi on my oil presure guage at idle cop tested at 160 low and 175 high i have a different carb on it so i hope its going to work great i had another luv two years ago it was 4wd 4spd and would run freeway like 4k on the tach all day long and 160--180
Users browsing this forum: Google [Bot] and 51 guests
