 Post subject: motor mount
PostPosted: Wed Sep 17, 2008 2:19 pm
ok ive had my luv for almost a year now. the problom i keep have is motor mounts i keep breaking them 4 wheelin . ive got 31 10.50s on the truck , weber carb, header and some more odds and ends . but what i want to know is there any soild mounts for these trucks or should i just go with the old "chain the motor to the frame" trick ?
DITCH DIGGER 16550
 Post subject: Re: motor mount
PostPosted: Thu Sep 18, 2008 8:25 am
That seems strange to me, I've never had problems with the motor mounts in any of my LUVs. Maybe I'm just not driving them right. :P You might want to look at the trans mount and make sure it bolted down tight and in good shape if you haven't looked it over for a while. Could be it is letting the whole works move around more than it should.
I'm not sure they will have anything for a LUV, but you might check with the parts department at http://isuzu.stcharlesauto.com/ for original equipment mounts. They might hold together better than generic replacements. I recommend you call their parts dept and talk to them as they will probably give you a better deal. They should be able to figure out what they got that fits but I believe Isuzu PUP mounts up to 86-87 or so for a G200 1.9L motor will bolt to the LUV, and possibly some of the later 2.3L and 2.6L mounts would as well.
PostPosted: Fri Sep 19, 2008 1:50 pm
I broke a left one on my 78 right after putting on a Weber and "testing" it out. It was old. I bought a new one... done. No more problems.
Users browsing this forum: Bing [Bot] and 67 guests
