It is currently Mon Jun 08, 2026 8:04 am
PostPosted: Tue Sep 16, 2008 11:26 pm
what does the 'C' stand for? on the guage cluster in a 75' luv. im having really bad problems w/ mine running.
thanks
PostPosted: Tue Sep 16, 2008 11:32 pm
Charge. Likely an alternator problem.
PostPosted: Wed Sep 17, 2008 10:15 am
thank you
PostPosted: Wed Sep 17, 2008 1:47 pm
No problem. :)
PostPosted: Sat Sep 20, 2008 12:42 am
If you describe the exact problem maybe someone has an answer, worth a try anyways...
PostPosted: Sat Sep 20, 2008 6:44 pm
so i was getting some after effects due to that hurricane up in northern indiana. and was out in my luv. i got stuck about 20 times in flooded roads trying to ease my way thru. so i had to go thru some pretty high water. i ended up stoping and leaving it at a guys house. came back had to change the plugs, and flood it out. but when i started driving it away it would keep dying when the "C" would light up. after words it would stay running. if anyone has an idea i have a week off coming up and would like to be able to fix it. thanks. by the way my truck is lowered so i had alot more water touching the truck then normal.
PostPosted: Mon Nov 10, 2008 12:03 am
I would say that the regualtor has got wet.
Swap it out with another one and see if that fixes it.
Bob.
