It is currently Mon Jun 08, 2026 2:08 pm
 Post subject: Cam timing marks
PostPosted: Mon Aug 18, 2008 9:55 am
have a series 10 truck and I believe a bad head gasket? I want to double check the cam timing before going too far, but the hayes manual I have does not have the explicit location of the marks on the sprocket in relation to tdc. Anybody know this?
 Post subject: Re: Cam timing marks
PostPosted: Mon Aug 18, 2008 9:48 pm
Cam timing is set with #4 on compression stroke.
At this point the line on the cam is pointing up. Its located on the front bushing, not the timing gear. What I used to do is, with the head off, turn the crankshaft to TDC. Take off the distributor cap and see if the rotor is pointing to #4. If it is not--rotate crankshaft one more revolution to TDC. With the head back on in this position both rockers on #4 will be a bit loose (rattle with some play in them, valves closed). At the same time #1 will have play in one rocker (intake valve) and no play in exhaust valve rocker as the valve is pushed open. At the next crankshaft revolution the process is reversed.
