It is currently Mon Jun 08, 2026 7:59 pm
 Post subject: Cam timing marks
PostPosted: Mon Aug 18, 2008 9:55 am
have a series 10 truck and I believe a bad head gasket? I want to double check the cam timing before going too far, but the hayes manual I have does not have the explicit location of the marks on the sprocket in relation to tdc. Anybody know this?
 Post subject: Re: Cam timing marks
PostPosted: Mon Aug 18, 2008 9:48 pm
Cam timing is set with #4 on compression stroke.
At this point the line on the cam is pointing up. Its located on the front bushing, not the timing gear. What I used to do is, with the head off, turn the crankshaft to TDC. Take off the distributor cap and see if the rotor is pointing to #4. If it is not--rotate crankshaft one more revolution to TDC. With the head back on in this position both rockers on #4 will be a bit loose (rattle with some play in them, valves closed). At the same time #1 will have play in one rocker (intake valve) and no play in exhaust valve rocker as the valve is pushed open. At the next crankshaft revolution the process is reversed.
Users browsing this forum: Google [Bot] and 51 guests
