It is currently Wed Jul 01, 2026 1:34 am
 Post subject: Power Valve. need help
PostPosted: Tue Jun 17, 2008 8:28 am
ok I have finished with the rebuild of my carb and realized that the power valve was not there. the spring and the screw. I would like to now were i can buy one I've been checking all over the net and have had no luck any help with this would be great. also how do you take the power valve off. I do have an old carb not sure if its the same but its very close to it and the valve seems to be able to fit. thank you for your help.
PostPosted: Tue Jun 17, 2008 8:34 am
I forgot to say that my carb is from a 1978
PostPosted: Tue Jun 17, 2008 10:54 am
i got a carb off a 79 they are basically identical, the top is off it but ide let you have it for the cost of shipping...
::edit:: it has all the parts ::edit::
