It is currently Tue Jun 30, 2026 7:30 pm
 Post subject: engine troubles
PostPosted: Thu Jun 05, 2008 6:15 am
hi all i am the owner of 1981 luv 4cyclinder carb engine and it wont start ! the engine turns over, but it is a hi pitch wine not like a regular engine would sound when turning over. if you can help thank you !
 Post subject: Re: engine troubles
PostPosted: Thu Jun 05, 2008 10:50 pm
uh all that comes to mind is possibly a brocken timing chain. When theres no compression (valves not moving) the starter will basicly free spool with the bottom end and make a higher pitch sound. So pull the valve cover and have someone crank the engine (or use a starter button) and see if the valves move...
Also im going to move this to stock trucks so it gets a bit more traffic.
PostPosted: Fri Jun 06, 2008 2:35 pm
That's what happened when my timing chain broke. Did it run before? Do *NNNNNOOOOOTTTTTT* try to bump start it, you will send metal chunks everywhere and ruin the motor. If it is the timing chain, you will have to remove the front cover, and if it is a 4x4 model, you will have to remove the motor. Also, inspect the timing chain bottom sprocket, mien was chipped and missing teeth!
PostPosted: Fri Jun 13, 2008 6:25 pm
It will also bend most of your intake valves. I have one sitting out in my garage right now.
1980 Luv 4X4
another 1980 luv 4x4
PostPosted: Fri Jun 13, 2008 6:50 pm
PITA Old Fart
You can add causing a possible screwed-up up head to that list...so just don't try to push start it.
Take the cover off, and if the valves don't move when you crank the starter or you can visibly see that the chain isn't connected any more, then you will have to fix it or get someone else to do it.
