It is currently Tue Jun 30, 2026 6:06 am
PostPosted: Wed Jun 04, 2008 8:05 pm
OK so I have gone through 3 or 4 oil pan gaskets, now. I have heard everything from snug to finger tight +1/4 turn. I need an EXACT torque figure-the manual only seems to list them for the FIRST generation Isuzu LUV motor. Dare I assume it is the same as the 11th gen?
PostPosted: Thu Jun 05, 2008 12:56 am
My book shows 4 Ft.lbs. which also equals 48 inch lbs.
PostPosted: Thu Jun 05, 2008 3:24 pm
usually you want to tighten them down untill the gasket just starts to smoosh out.
the speck my book gives is 43 in-lbs.
PostPosted: Fri Jun 06, 2008 2:33 pm
Gotcha. Thanks guys!
PostPosted: Fri Jun 06, 2008 3:06 pm
My truck has been giving me fits, I have replaced 3 pan gaskets and the last one had enough gasket sealer on it it should have stuck for ever. It seems to be leaking on the pan where the oil filter screws on. Well I can't get my big fat head close enough to really see so I guess I'll pull the sob and try to locate the leak for sure.
PostPosted: Fri Jun 06, 2008 6:32 pm
You need to tighten it down evenly. That's why you watch the gasket, and don't smoosh it out more in any one place. Also, tighten it down like you do a cylinder head, in a staggered sequence.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Jun 06, 2008 6:43 pm
Australian LUV Guru
*edit by mod*
Let's not start any more drama around here, okay?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri Jun 06, 2008 7:31 pm
Sure,I was thinking I had most of your Aussie's lingo down,then ya'll start talkin plain English.
