It is currently Mon Jun 29, 2026 9:37 am
PostPosted: Mon May 26, 2008 12:00 am
I have a pinhole in the front of the radiator on my firewood truck and I am wondering how difficult of a job it is to remove and replace it? Any special tips or tricks I should be aware of before I attempt the job?
http://www.purerockradio.net/
PostPosted: Mon May 26, 2008 12:41 am
have pulled 4 of them and they are very easy, 4 bolts and the hoses then slide out... if you have the shroud unbolt it and slide to the motor then just lift out the radiator
PostPosted: Mon May 26, 2008 10:21 pm
Thanks! I kinda figured it wouldn't be too difficult. Thanks for letting me know. The other one I am going to try to put in came with a bunch of extra parts when I bought the firewood truck. Is there anything special I need to do with the replacement radiator? I should probably flush it out with water first I suppose.
PostPosted: Tue May 27, 2008 1:27 am
just check it over and a good flush is all i have done to mine... and i have found that there are 2 different type drain plugs , just fyi
PostPosted: Tue May 27, 2008 2:38 am
Didn't know there were 2 kinds of drain plugs. All I have ever noticed is the little white plastic one. Thanks again.
PostPosted: Tue May 27, 2008 7:33 pm
i think they where different sizes if i remember right... i do remember having a rad sitting around that was good so i took the leaky one out of the truck and tried to put the plug in the other one and if i remember right it was to big
Users browsing this forum: Google [Bot] and 93 guests
